Activity › Forums › Apple Final Cut Pro Legacy › Is Tiger 10.4.2, FCP 5.1 and Quicktime 7.0.4 Stable?
  • Is Tiger 10.4.2, FCP 5.1 and Quicktime 7.0.4 Stable?
    Posted by Hoop Dreams on July 14, 2006 at 9:09 pm
    For the last two weeks I’ve been having issues with Tiger 10.4.7, FCP 5.1.1 and Quicktime 7.1.
    I was reading on here that Tiger 10.4.2, FCP 5.0.2. and QT 7.0.4. is stable. My only problem is that I don’t have 5, but 5.1. so if anyone knows how stable that combo is, I would be greatful.
    Thanks in advance, Ian
    Dual 2 GHz PowerPC G5
    3 BG DDR SDRAM
    AJA Kona SD
    Kevin Monahan replied 20 years, 2 months ago 3 Members · 3 Replies
  • Walter Biscardi
    July 14, 2006 at 9:25 pm
    With 5.1.1 you do NOT want to step back. If you’re having stability issues, I would suggest you run something like Disk Warrior on your system drive to see if there are any errors.
    FCP 5.1.1, 10.4.7, QT 7.1 is rock solid here and I haven’t really heard much about stability issues with this setup.
    Walter Biscardi, Jr.
  • Hoop Dreams
    July 14, 2006 at 9:42 pm
    Thanks for the fast reply!
  • Kevin Monahan
    July 15, 2006 at 5:42 pm
    I was having trouble with my slower and older Macs on 10.4.7, turns out that removing my KVM switch helped greatly. Appears that Tiger is more sensitive to 3rd party hardware and bad RAM than past versions of OS X.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
