Activity Forums VEGAS Pro is this possible? svideo on sony vegas
  • is this possible? svideo on sony vegas
    Posted by Aalleexx on July 21, 2007 at 12:45 am
    I am really confused, look here is my rig
    sony vegas 7, nvidia quadro fx 1500 and 2 19″dell 1905fp monitors
    now what I want to do is use a tv I have laying around as another preview device and want to go from the graphics card to the tv via s-video, is this all posible in sony vegas? while still using my two dell monitors, see I want to use the tv to preview my final product, thanks guys
    Douglas Spotted eagle replied 19 years, 2 months ago 3 Members · 7 Replies
  • 7 Replies
  • Douglas Spotted eagle
    July 21, 2007 at 1:52 am
    While you can use an Svideo output from a graphics card, it’s not advisable for many reasons.
    If you’re using DV as your source, or want to preview at an SD-quality, then you can use a camera, deck, Convergent Design or similar converter to use the 1394 bus on your computer as a video output, that will be converted from digital to analog. This is by far the most accurate and efficient way to see your image correctly scaled, colored, etc. from the Vegas timeline.
    Douglas Spotted Eagle
    VASST
    Aerial Camera
  • Aalleexx
    July 21, 2007 at 2:07 am
    well I am using 720 Hd but want to preview at a sd quality please tell me what I gotta do in order to use the tv and pc using the s-video cable, is it posible and while still using the other two dell monitors? I ask this becuase on the vegas prefrences it gives you options for your preview device and s video connection is not one of them it was ilink,windows secondary display and something else, please tell me what to do thanks
  • Edward Troxel
    July 21, 2007 at 3:06 am
    Computer -> Firewire -> Camera/Deck/Convertor -> S-Video -> TV
    Edward Troxel
    JETDV Scripts
  • Aalleexx
    July 21, 2007 at 3:33 am
    ok now one last question, this looks complicated and not really worth it, see one of the features of my graphics card is that it has a hd 7 pin out, nvidia says.. this is straight from the website
    “Integrated HD Component, S-Video and Composite Video Output
    “7-pin HD out connector and the PNY Technologies Professional Video Breakout Box provide graphics to HD component video (YPrPB), S-Video, or composite video out to enable real-time output to HD broadcast monitors, video recorders, or other video peripherals – enhancing the capabilities of nearly any 3D design, DCC, video editing, medical imaging, or visual simulation application.
    Supported video formats include:
    July 21, 2007 at 5:38 am
    Yes, you could use this for HD preview, but much like the SVid output, it’s not generally accurate to the signal. This varies with different cards, however. Use calibration tools to check it; it’s pretty easy to see what’s going on.
    For HD monitoring, DVI/HDMI/SDI are the preferred methods for accuracy, and even then, you may not be seeing it 100% true.
    https://www.vasst.com/training/OHCI.htm>tutorial that shows how to connect via a converter device for SD preview
    VASST
    Aerial Camera
  • Aalleexx
    July 21, 2007 at 6:22 pm
    could you please give me some pointers on exactly what I have to do to connect the hdtv to my pc for vegas preview
    thanks
    July 22, 2007 at 10:02 pm
    What inputs are available on your HDTV? That’s the most important component (no pun intended) to the answering of your question
    VASST
    Aerial Camera
