Activity Forums Media 100 Is this possible.
  • Is this possible.
    Posted by Gregg Michaels on January 12, 2010 at 7:45 pm
    Hi guys. Is it possible to see user marks in the timeline from within the composite suite (Red) interface? If not, would love to add it to the wish list.
    GM
    Gregg Michaels replied 16 years, 8 months ago 2 Members · 2 Replies
  • Wickham Strub
    January 13, 2010 at 3:22 pm
    Sure you can do that!
    Boris RED can read user marks applied to either the Media 100 Program or the individual clips (you did know you could apply marks to clips in the Edit Suite, right? 😉
    When you get into Boris RED…
    – Go to the “Window” menu and choose “Show User Marks Window”
    – In the “User Marks” window, click on “Import Host Marks”
    – Voila!
    While your messing around with this sort of thing, you may also want to choose “Show Timecode Palette” from Boris RED’s “Window” menu and then choose “Host Timecode”. This sets up RED to use the actual timecode numbers from your timeline.
    ~ Wick
  • Gregg Michaels
    January 13, 2010 at 3:31 pm
    That is most excellent! Had already found the timecode palette, which I’ve been using quite a bit.
    Thanks Wick.
    GM
