Is this FCP7 issue or Vimeo issue (Absurd color drop midway though clip playback)?
Hi folks,
I’ve had this issue before and looked for resolution here but no luck but here I have it again with different footage and I mean there must be a solution…YES I’ve trawled creative cow and other forums and faqs looking for answers but found nothing)
I’ve been having a recurrent problem with sudden colour drop/darkening issues with my uploads to vimeo. It’s happened on my last two uploads (exported from FCP7 as H.264 and following all of the guidelines on the vimeo upload advice page etc)
I’ve followed all of the compression export recommendations exactly as advised but still this issue persists; I wouldn’t mind if it was just a case of clips appearing darker or lighter when uploaded but this is a case of clips starting with one look and then dropping/darkening colour mid-way through the playing of that particular clip.
I could probably get away with this happening once or twice but as you’ll see in the video itself its actually happening several times and looks terrible.
https://vimeo.com/132806384 (times issue occurs at listed below)Finally there is also some issue with pixellation at 02:43 – 02:44 which is a first and looks equally bad.
Playback of H.264 file is fine on my system it’s only on upload that this occurs. I need to re-upload anyway as the audio is a little low but I’d really like to not only sort this issue for this video but prevent it from occurring in future uploads.
If any of you have any experience of this issue and could point me in a direction that would help me solve it i’d be massively grateful. If you need any further information from me just let me know and I’ll pop it on here.
Thanks and best.
01:07 -01:09
01:14 (split second darkening and lightening)
02:03
02:09
02:23 -02:24
02:32 -02:33
02:35 -02:36
02:43 -02:44 PixellationSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
