Is this a track matte issue? (SOLVED)
Hello, I’ve searched everywhere and have watched a ton of tutorials over the last week trying to figure this out.
In the picture below you can see the words “IN THE BEGINNING” and “a revolutionary idea”. These words are way too small after I render and watch on a tv. The problem is when I make the words bigger, there is a rectangle shape that is over the words. This is to allow the image to drop down and act as if it is appearing out of the middle of the screen.
When I make the words bigger I would like the rectangle shape to be bigger as well but I just can’t figure this out.
Please help!
This problem resides in the “First Step” highlighted in the image below.
This image shows after double clicking on “First Step”.
This image shows the rectangle shape that is hiding the words “IN THE BEGINNING”.
This image shows where the track matte is on Alpha Inverted Matte “Shape Layer 2”.
This image shows that changing the Track Matte to “None” takes this rectangle shape away revealing the words “IN THE BEGINNING”.
This image shows what it looks like after enlarging the words “IN THE BEGINNING” with the “Alpha Inverted Matte “Shape Layer 2” enabled.
This image shows how the “Alpha Inverted Matte “Shape Layer 2” follows the words “IN THE BEGINNING” across the screen.
I hope these images can give you an idea of what I am trying to fix.
Thank you for your time in advance! It is much appreciated!
Ryan
