Activity Forums Apple Final Cut Pro Legacy Is this a FCP or Color problem
  • Is this a FCP or Color problem
    Posted by Paul Witcher on November 12, 2009 at 1:50 pm
    Hi Guys,
    I have posted this query before in the color forum, but got no response (not sure if that was because I was being silly)
    Issue – after sending project to color one particular clip is in red (off line I believe) can’t see it in color at all. I can grade the other clips all OK, and send back to FCP, and everything is fine.
    So, what is wrong with this clip??
    Some background – FCP 7 color 1.5 shot in HDV and captured with ProRes 422
    This particular clip is 04:27 long, this is the only difference from the other clips i.e. the length. So I captured the clip again but this time for about one minute, and sent it to color and I could see it and grade OK.
    This is quite baffling, as at the moment I’m testing FCP for a documentary I will start shooting next year that will take me perhaps 3 years to shoot (summer only) then I will edit in between times.
    The rest of the testing has been successful, using split screen – transitions – speed changes – titles etc – send to color graded sent back and produced a SD DVD fine.
    My fear is that due to the material type it could be that I will have a few clips this long to grade.
    Any light you can shine on this would be very helpful
    Paul
    Paul Witcher replied 16 years, 9 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    November 12, 2009 at 4:36 pm
    I’d think this is an anomoly.. I do the same with HDV (capture as ProRes through firewire, or through an IoHD and never seen the problem…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Paul Witcher
    November 12, 2009 at 5:48 pm
    Thanks Jerry, I guessed as much – I just wanted to check I wasn’t missing something.
    Paul
