Activity › Forums › Adobe After Effects Expressions › Is there still no way to control ‘shy’ in an expression?
  • Is there still no way to control ‘shy’ in an expression?
    Posted by Chris Meadmore on August 20, 2020 at 8:53 am
    A lot of posts suggest not but they’re all quite old now.
    Is there any way to currently shy a layer on/off using expressions? You can control if a layer is active which isn’t a keyframe-able value so why not shy?
    Filip Vandueren replied 6 years, 1 month ago 2 Members · 1 Reply
  • Filip Vandueren
    August 20, 2020 at 2:05 pm
    They can’t, but expressions also can’t control if a layer is active.
    No more than they can change the layer order, the label color, the quality setting,…
    Expressions are by definition only applied to keyframe-able properties.
    Why would you need an expression to shy a layer, it has no effect on the render?
    Scripting can set the .shy property of a layer without a problem though.
