Activity Forums Adobe Encore DVD Is there no way of making Encore authored DVDs play in Windows Media Player?
  • Is there no way of making Encore authored DVDs play in Windows Media Player?
    Posted by Daniel Haskett on August 28, 2005 at 2:54 pm
    Hi there
    Basically I seem to find that when I make a DVD in Adobe Encore it will play in Power DVD and standalone players, but Windows Media Player and Realplayer dont seem to like it. I have a job coming up where I really need to make it so the DVD players in WMP, if I cant I could quite possibly loose the job. Is Encore just not made for industry standard? I dont know what they normally use…. is there a way of doing something to it after, like reburning in Nero as a DVD video?
    Thanks in advance!
    Dan
    Ducati replied 21 years ago 3 Members · 2 Replies
  • Joe Bowden
    August 28, 2005 at 4:03 pm
    Encore-authored DVDs play fine in WMP on all my systems.
    The key is that a software DVD player (such as PowerDVD) must be installed on a system in order to playback DVD-Video. Windows Media Player alone does not have the licensed MPEG-2 video decoders required for playback.
  • Ducati
    August 30, 2005 at 12:38 pm
    Is it possible that you have “the copy protection” on? I had problems with the error message (something like this) “This image has sector headers and needs to be removed, remove and continoue” after my update, so I was pushing yes, and the dvd was burnt as if nothing happend. This turned out to be a problem. The dvd’s did not work with “winplayer” or on any apple computers, ohps problem! Anyway – I learnt that this was the copyprotection that needed to be turned off, but they were already off!?! Yes they were, acctually they were never turnet on from the beginning. So I had to turn “eveything on” save a projekt. Then restart my pc, open the project I just saved, turn “every thing off” again – save as… to a new folder – reboot my pc… and it is magic – it is solved. I have no more problems, it playes in “winplayer” and on my ibook again.
    But some of my old projects still has this problem – then I “just” 😉 do the same precedeur again. I don’t know if this is your problem, if not…Zzzzz 😉
