Activity › Forums › Adobe After Effects Expressions › Is there expression or function that reads what type of layer, a layer is?
  • Is there expression or function that reads what type of layer, a layer is?
    Posted by Auric johnson on October 1, 2020 at 6:34 pm
    for instance if I were to type the expression/function (lets say its called .type) into a text layer source text, the text would say “text layer” if I were to have a comp above that text layer and typed the expression with an index-1 the text would say “comp”.
    I want to write an if statement that executes one function if there is a text layer above and another if there is a comp.
    something like
    if(thisComp.layer(index-1).type==”comp”)”its a comp”;”it can be text”
    so yea just wondering if such a function exists
    thanks,
    Auric johnson replied 5 years, 12 months ago 3 Members · 3 Replies
  • Dan Ebberts
    October 1, 2020 at 7:19 pm
    Not exactly, but you could do something like this to test for a text layer:
    try{
    thisComp.layer(index-1).text.sourceText;
    isText = true;
    }catch (e){
    isText = false;
    and something like this to test for a comp layer:
    try{
    isComp = thisComp.layer(index-1).source instanceof Comp;
    }catch (e){
    isComp = false;
  • Filip Vandueren
    October 1, 2020 at 7:23 pm
    I don’t think so actually.
    Maybe it’s best to test for properties that only certain types of layers have ?
    l=thisComp.layer(2);
    layerKind="unkown";
    if (l.text) layerKind = "Text";
    else if (l.source) {
    layerKind = "Footage";
    if (l.source.duration ==0) {
    layerKind = "Solid/Null/Still";
    if (l.source.numLayers!=undefined) layerKind = "Composition"
    } else if (l.cameraOption) layerKind = "Camera"
    else if (l.lightOption) layerKind = "Light"
    layerKind
    Can’t find a way to discern between Solids, Nulls and Stills though…
  • Auric johnson
    October 2, 2020 at 9:00 am
    Hey Thanks for this! I used the first one and it works like a charm
    a=thisComp.layer(index-1).sourceRectAtTime();
    t=a.top;
    h=a.height;
    som = t+h/2;
    p=thisComp.layer(index-1).position[1]
    fs=text.sourceText.style.fontSize
    y1 = (p+h+fs);
    y2 = (p+som/2);
    x =thisComp.layer(index-1).position[0]
    try{
    isText = [x,y1];
    }catch (e){
    isText = [x,y2];
    This basically will space out any text layers below the above text layer by the font size but because the title its own comp I needed to calculate the spacing differently, seems to work cheers
