Activity › Forums › Apple Final Cut Pro › Is there border or drop shadow?
Posted by Vigen Kachikean on July 22, 2011 at 2:52 amHi everyone i’m looking for border and drop shadow but can’t find it. Is it missing or i’m looking in wrong place i checked all the tabs can’t find it.
Thanks in advance.
Vigen Kachikean
Northridge Filmworks
Northridge, CAVigen Kachikean replied 15 years, 2 months ago 3 Members · 6 Replies -
Brendan Gibbons
July 22, 2011 at 7:24 amYes, drop shadow is an obvious missing function from the inspector.
A few people here have got around that by publishing parameters from motion and creating useful presets for FCP X.
Simon Ubsdell has created many great presets which incorporate borders, boxes and shadows etc.
For example:
https://f1.creativecow.net/2608/new-fcpx-adjustable-frame-effect-with-position-osc-and-edge-feather
Check out his file page for many different variations that he has built.
https://my.creativecow.net/Simon-Ubsdell/files
Cheers,
Brendan
Vigen Kachikean
July 22, 2011 at 7:22 pmThank you for the responds Brendan. BTW it’s amazing how you and others come up with these effects so fast, do i need Motion 5 to use these effects?
Thanks again.
Vigen Kachikean
Northridge, CA -
Brendan Gibbons
July 22, 2011 at 8:07 pmHi,
You don’t need Motion 5 installed to use custom presets that people have built, BUT you do need to a specific folder structure for it to work.
I’ve uploaded a pdf outlining the procedure.
Installing FCP X user presets without having Motion 5 installed
Thanks to Mark Spencer for pointing this out.
Cheers,
Brendan
Vigen Kachikean
July 23, 2011 at 5:17 amThank you very much for the info.
Vigen Kachikean
Northridge, CA -
Simon Ubsdell
July 23, 2011 at 8:14 pmHi Vigen
Here’s a simple template that is specifically a border and drop shadow effect – with all the available controls from Motion.
I’ve included a background that you will probably want to turn off but it will help you see what you are doing as you set up the border and drop shadow.
Hope it’s useful to you.
Simon Ubsdell
Director/Editor/Writer
http://www.tokyo-uk.com -
Vigen Kachikean
July 26, 2011 at 5:33 amThank you so much.
Vigen Kachikean
Northridge, CA
