Activity › Forums › Adobe After Effects › Is there anyway of using the 3d extruder tool on normal layers that arent shapes?
  • Is there anyway of using the 3d extruder tool on normal layers that arent shapes?
    Posted by Daniel Haskett on October 19, 2007 at 11:51 am
    Hi there
    Basically ive got some kind of cut out drawn buildings that ive made in photoshop and i want them to be 3d in AE. i know that i could do this all manually…but i was just wondering if there is anyway of using the 3d extruder tool to do it, so basically they are just made 3d blocks….i know u can do it with shapes and text, but can u do it with normal layers, or does anyone have any tips on how this could be acheived?
    cheers!
    dan
    Darby Edelen replied 18 years, 11 months ago 6 Members · 6 Replies
  • Mike Clasby
    October 19, 2007 at 12:05 pm
    Aharon does an interesting thing with Z Space and buildings here:
    https://library.creativecow.net/articles/rabinowitz_aharon/z_scale.php
    Don’t know if that will help.
  • Daniel Haskett
    October 19, 2007 at 12:25 pm
    Hey Mike
    Thanks for that, much appreciated. Do you know where i could find the project files for that tutorial? i just want to see exactly how he did the building effect as he only goes over it very briefly in the tutorial…
    cheers
    dan
  • Tim Wilson
    October 19, 2007 at 3:03 pm
    Check that page again. The link to the files is just above the link to play the movie.
    tw
    tim(at)creativecow(dot)net
    My Cow Blog
    Join my LinkedIn network
  • Ronaldo Montalvo
    October 19, 2007 at 6:19 pm
    you might want to look at the vanishing point plug-in that comes with photoshop CS3. i believe it does just what you’re looking for and allows you to export the 3D info and pshop layers as a comp directly to AFX8 where you can then do camera moves on the “3D” still. pretty nifty. there’s a demo on working with vanishing point in afx and photoshop at the adobe design center:
    https://www.adobe.com/designcenter/video_workshop/
  • Lifetypo
    October 19, 2007 at 10:54 pm
    i wish aharon would make a tut on building that city he did in the end of that tutorial ..
  • Darby Edelen
    October 20, 2007 at 2:34 am
    Try making each building out of 3D solids in its own composition. Here are a couple of hints:
    -Use dimensions for your solids that are easy to remember/replicate like 200p x 600p for the 4 walls and 200p x 200p for the ceiling and floor.
    -Move the anchor points for all of your solids to [0,0] to make the math of lining things up easier on yourself.
    -Rotate your layers 90
