Activity › Forums › Maxon Cinema 4D › Is there any way to triangulate a bucky?
  • Andy Kiernan
    April 28, 2022 at 8:23 am
    maybe, make editable, select all polys then run inset/ inner extrude command, then pull the new points toward centre of each poly and then merge the new points into one?
  • Andy Kiernan
    April 28, 2022 at 8:53 am
    *Correction… I forgot about the division on the face, you will need to do that process on each 5 sided shape, and have preserve groups on within the inset tool. and use the collapse command to merge the new points together.
  • Hilary Tsai
    April 30, 2022 at 9:23 pm
    Thank you so much! I’ll try this and get back to you.
