Activity › Forums › Adobe After Effects › Is there any way to restrict the selection tool to only 1 axis when moving a 2D object?
  • Is there any way to restrict the selection tool to only 1 axis when moving a 2D object?
    Posted by Freddie Hill on May 27, 2011 at 5:53 pm
    Hello, is there any way to get the selection tool to restrict movement to only moving 1 axis at a time? (if you are moving a 2d object)
    As in if I wanted to move the position of a 2d circle to the right but didn’t want to change the position of it on the Y axis.
    Anders Hattne replied 15 years, 4 months ago 3 Members · 2 Replies
  • Kevin Camp
    May 27, 2011 at 6:01 pm
    start dragging the layer, then hold shift to constrain the movement to horizontal or vertical.
    or drag the x or y position value for the layer in the timeline
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Anders Hattne
    May 31, 2011 at 11:23 am
    Another way would be using an expression> alt click the stopwatch for position and write in the field
    [value[0],460]
    the first part value[0] means it will use the value of the 1st dimension, and the second part will be the Y value, in this case 460. Change this to the value you want. In this case the object will be locked in Y at 460 pixels while you can move it in X
    I occasionally use this for locking a layer in postion, writing its center position. That way I won’t accidently move it while I can still change its opacity or scale.
    http://www.ardillamedia.com
