Activity Forums VEGAS Pro Is there any way to PLAYBACK footage in Sony Vegas Pro 13 faster/slower?
  • Is there any way to PLAYBACK footage in Sony Vegas Pro 13 faster/slower?
    Posted by Alex Black on September 29, 2015 at 12:05 am
    I am wondering if there is any way to speed or slow the preview without affecting the clip itself (eg. No I do not want to use velocity envelopes or time-stretching). I just need the PREVIEW to be faster/slower because I need to cut down on editing time. Any advice?
    David Eon replied 10 years, 9 months ago 5 Members · 5 Replies
  • Mike Kujbida
    September 29, 2015 at 1:01 am
    Use the J K L keys. J is reverse, K is pause and L is forward. Pressing the J or L keys more than once speeds up or slows down playback. 1, 2, 4 & 8 times as I recall.
  • Wayne Waag
    September 29, 2015 at 3:35 am
    You can further adjust speed under Preferences|Editing|JKL/shuttle speed.
    wwaag
  • Alex Black
    September 29, 2015 at 5:00 am
    Exactly what I was looking for. And the chipmunk voice “side effect” of playing back speeded up footage is hilarious too. Thank you very much, Mike.
  • Aleksey Tarasov
    September 29, 2015 at 9:04 am
    Another way – using the scrub control:
    Vegasaur.com
  • David Eon
    October 29, 2015 at 1:39 pm
    I use the small triangle node below the scrub control – drag it all the way to the right to set default playback at 4x speed, then use ENTER to playback at 4x and L to playback at 1x. You have to reset the node each time you restart Vegas though. Let me know if that helps.
    DavidEon
