Activity › Forums › Adobe After Effects › Is there any way to import 3DS file into After Effects CS6?
  • Is there any way to import 3DS file into After Effects CS6?
    Posted by Adirai Maji on June 29, 2015 at 7:05 am
    I just want to know is there any option to import 3DS file into after effect CS6? If there is any plug-in available to make this possible?
    In older version of after effect can import 3D objects in PSD format (Initially I’ve convert 3DS file into PSD) But AE CS6 doesn’t have this feature 🙁 please help me…
    Thank you 🙂
    ~MAJI~
    Chris Zecco replied 11 years, 2 months ago 3 Members · 4 Replies
  • Chris Zecco
    June 30, 2015 at 6:56 pm
    Hello Maji,
    There is a program called “Element 3D” made by video copilot that will allow you to do this. Although, I believe the CS6 and on have Cinema 4D Lite built into it, so you might want to check out that route if you will be doing 3D renderings often.
    Chris
    2012 Mac Pro
    2x 2.4GHz Intel Xeon
    24GB RAM
    1GB ATI Radeon 5770
    2011 Macbook Pro
    2.4GHz i7
    8GB RAM
  • Joseph W. bourke
    July 1, 2015 at 4:56 pm
    As Chris said, Element 3D will take 3D file imported from other packages. I’ve had it successfully take .obj files exported from 3DS Max, Blender, as well as CAD files imported to 3DS Max and saved out as .obj files. It will take C4D files as well, but I’ve had scattered luck with that (probably depends on the version of C4D the file was saved from).
    Zaxwerks makes 3D Invigorator Pro, which does a lot of what Element 3D does, but I don’t know whether it’s as fast at rendering as Element 3D. You can try out either of these, and see which you prefer. Much of it depends on your workflow, and what 3D packages you might own. But back to your question, there is no way to directly import a 3DS file to After Effects CS6.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Adirai Maji
    July 1, 2015 at 5:24 pm
    Thank you Chris for your information 🙂 ,
    I do know about Element 3D. I’ve some trouble here. Unfortunately my GPU isn’t satisfies the requirement of Element 3D Plug-in (I’ve Intel Graphics cards). Even if we have perfect system requirement, Element 3D only supports *.C4D *.OBJ *.E3D files and it won’t support *.3DS files.
    What should I’ve to do now?
    ~MAJI~
  • Chris Zecco
    July 1, 2015 at 7:36 pm
    Have you tried exporting a PNG sequence from 3DS Max?
    2012 Mac Pro
    24GB RAM
    1GB ATI Radeon 5770
    2011 Macbook Pro
    2.4GHz i7
    8GB RAM
