Activity Forums Avid Media Composer Is there any way to get a file larger than fat32 file size limit from a mac to a PC?
  • Is there any way to get a file larger than fat32 file size limit from a mac to a PC?
    Posted by Matt Wafaie on July 7, 2006 at 8:13 am
    I desperately need to get a 13 gigabite video file from a mac to a PC. Mac Opener does not work. No PC I try with NTFS drives can recognize a mac drive with mac opener. Is there any way in the world that I can transfer a 13 gb file from a mac to a PC? Please help.
    M@
    Ben Wharton replied 20 years, 1 month ago 5 Members · 4 Replies
  • Majorasshole
    July 8, 2006 at 4:28 am
    find a free FTP or web server
  • Praxisseizure
    July 10, 2006 at 2:46 am
    mac drive. it’s free for 15 days. works like a charm.
  • Dark Russell
    July 10, 2006 at 8:24 pm
    I agree…or get PC Maclan and copy between machines.
  • Ben Wharton
    July 13, 2006 at 11:20 pm
    Or a slightly different route –
    Why not zip or RAR the file up into a set of files? WinRAR (maybe Winzip too) will allow you, via “split to volumes” to divide up one file into many – say each of 650Mb.
    So that will give you around 20 files.
    Then burn the files to 3 DVD Data disks. If you want/can create chunks that are bigger than 2Gb remember to create a UDF formatted disk, NOT an ISO.
    Then copy the files over to your Mac from the DVDs and unzip / unrar the first file which will reconnect all the others in the series and voila you’ll have your 13Gb of footage ready to use on your Mac.
