Activity Forums VEGAS Pro Is there Any way to Connect Clips with EASE??!! PROBLEM!
  • Is there Any way to Connect Clips with EASE??!! PROBLEM!
    Posted by Jojo Carreiro on December 23, 2011 at 12:06 am
    Connecting Clips in Sony Vegas is a Pain! Is there anyway theres some kind of setting or shortcut where you can Connect them Easily instead of like Zooming and carefully putting them in place so they do NOT make a transposition! It wastes alot of my time and if there was an EASIER solution i would THANK ANYONE who helps! ALOT! you will be my hero 😉
    Rob James replied 14 years, 8 months ago 3 Members · 2 Replies
  • Aleksey Tarasov
    December 23, 2011 at 4:09 am
    Do you mean the easy way to place a few scattered events side by side?
    Afaik, there is no solution out of the box. But you can try to find a free script that can do this or
    use commercial tools, like Vegasaur, which contains such commands and much more.
  • Rob James
    December 23, 2011 at 4:13 am
    Jojo, it’s really quite simple. Make sure your snap is on, then when dragging clips close to another, a line should light up, signaling you’ve joined a clip to a clip, no matter how far you are zoomed out. The only way you are not witnessing this, is that your snap is off. Hope that helps?
    Rob,
    https://www.robjames.net
