Activity Forums Apple Final Cut Pro Is there any way to connect clips that were edited as 30fps to the same clips reverse telecined to 24fps?
  • Is there any way to connect clips that were edited as 30fps to the same clips reverse telecined to 24fps?
    Posted by Noam Osband on May 20, 2017 at 1:39 am
    I did reverse telecine on these clips in Compressor. I had logged and edited with the clips at 30 fps. If I try to relink those clips to the version that is now 24fps, FCP X doesn’t let me relink. It tries to relink but tells me they’re incompatible.
    I’m guessing there’s no work around. But i figured I’d ask first. Is there any way to connect the logging I did to the new clips?
    Noah Kadner replied 9 years, 3 months ago 3 Members · 2 Replies
