Is there any problem, loss of quality or issue w copying and pasting from one SONY MS project into a new project?
Hello,
Certain parts of my project got messed up as far as the titles and sound not staying in alignment w the video track.
I had edited it in two chunks – both on the same timeline in the same project.
But I always have trouble as I will need to edit something in the middle of the timeline and by the time I am done, it throws the other segments, clips, titles sound, out of alignment further down the timeline.
I know I can use the, “group” feature and that will prob help but it’s tricky to group, and then sometimes you need to ungroup and then there is the ripple that needs to be turned on or off so I find it somewhat tricky to keep the video,sound etc intact.
So – the project was sorta in two segments but both on same timeline/project.
So I went back to where I had saved the project a month ago, where the second half (on same timeline) was still intact i.e. the sound and video were not out of alingment and copied and pasted it into the more recent file where the first part was still intact correctly so that way, I didn’t have to mess around w trying to correct everything. I.e. there were multiple sound clips and they all got totally discombobulated so I just copied from prior time when the sound matched the video and pasted it into the more recent file/timeline.
I know the software draws off clips in the drive so I don’t think I will lose any quality – but that is what I am asking?
Any downsides?
The sound track turned from blue to purple. Does that mean anything?
Thanks for any help! I’m close to being finished w the project. Four years in the making! Well I only worked on it periodically but it’s still 4 years since I started.
Lenovo quad core i7 16gb of ram, Windows 8.1 MS 13 64 bit
