Activity Forums Adobe Illustrator Is there an efficient way to draw a light diffraction in Illustrator?? (see pic)
  • Is there an efficient way to draw a light diffraction in Illustrator?? (see pic)
    Posted by Amanda Bruce on September 8, 2010 at 2:53 am
    I am trying to do something like the attached photo. It’s a series of about 40 sets of circles that “radiate” outward, but only the circle itself gets larger, not the width of it. is there any efficient way to accomplish what i am describing? rather than drawing circle after circle, measuring, drawing another circle, etc. thanks in advance. AB
    Amanda Bruce replied 15 years, 11 months ago 2 Members · 2 Replies
  • Les Nemeth
    September 8, 2010 at 9:16 am
    Refer to the enclosed image.
    1. Draw 3 parallel lines. Set thickness as desired. Select all three and drag it to the Brushes palette and create an Art Brush from it. Accept default options for the brush.
    2. Just for illustration, now when you draw a circle, select it, and apply the created brush, you get this.
    3. Now back to the project. Draw a small circle and a big one. (Due to lack of space, I’m going to illustrate this using smaller circles.)
    4. Select both circles and blend (Object > Blend > Make). Still selected, bring up the Blend Options dialog (Options > Blend > Blend Options…), set Spacing option to Specified Steps, and type in the desired steps value. Don’t make it too tight.
    5. Now select the blended circles and just apply the created brush to it. Adjust spacing and such as necessary.
    6. Copy/paste the result and position them as you like. Depending on how big you make the circles in step #3, the result will look like the one you specified.
  • Amanda Bruce
    September 8, 2010 at 1:32 pm
    Wow. thank you SO much for the short tutorial. It will help me out greatly!!! Thanks again, I appreciate your time!
