Activity Forums Avid Media Composer Is there an easy way to zoom in on keyframes?
  • Is there an easy way to zoom in on keyframes?
    Posted by Milton Hockman on October 19, 2006 at 6:04 pm
    i am keyframing an effect that changes every frame. it is hard to click on the right keyframe in the source monitor. how can i zoom in on them or make it easier to select the right one?
    Milton Hockman replied 19 years, 10 months ago 2 Members · 2 Replies
  • Michael Hancock
    October 20, 2006 at 12:43 am
    Yes, you can zoom in. When you’re in effect mode, just to the left of the starting keyframe, you’ll see a little bar. Grab it with your mouse and drag it (either to the right or left. Can’t remember at the moment). This will zoom in on your keyframes.
    And if you didn’t know, once you select your keyframe(s) you can move them with the trim key shortcuts (m , . / ), as well as holding Alt+dragging them.
    Mike.
  • Milton Hockman
    October 20, 2006 at 2:52 am
    for some reason i am pressing the . and , keys to move the playhead and it is not working. only the left and right arrow keys work, but they are only moving in fields, not frames.
    what is up
