Activity › Forums › Apple Final Cut Pro Legacy › is there an easy way to offset a bunch of clips after a Multicam Edit
  • is there an easy way to offset a bunch of clips after a Multicam Edit
    Posted by Max Huggett on July 10, 2009 at 5:41 am
    Hi Guys
    I have edited a long sequence using Multiclip, and i can now see that one of my 3 clips, is 3 frames out. I have already done alot of editing to the sequence and would hate to redo it all. Is there a way to shift in time, the one piece of fotage. I used the inpoint technique to sync. Would adjusting the inpoint for that clip now, ripple through to my sequence?
    Max
    Ian Liuzzi-fedun replied 17 years, 2 months ago 2 Members · 1 Reply
  • Ian Liuzzi-fedun
    July 10, 2009 at 4:17 pm
    That will not work. I have had this issue before and unless someone has a better answer I wind up having to go through all of the footage and move it back the amount desired. The other thing is doing a find in the timeline for the specific clip and then slipping it back the amount you want.
