Activity › Forums › Adobe After Effects › Is there an easy way to move to CS5.5 from CS5
  • Is there an easy way to move to CS5.5 from CS5
    Posted by Dustin Bowser on July 27, 2011 at 9:31 am
    I’ve got my After Effects CS5 tricked out with custom scripts, keyboard shortcuts, workspaces, and plugins. Is there an easy way to get up and running with CS5.5 and easily get back all of my customized stuff without having to redo it piece by piece?
    Eric Kirk replied 15 years, 2 months ago 3 Members · 2 Replies
  • John Cuevas
    July 27, 2011 at 1:14 pm
    As I wasn’t changing computers, I grabbed my plugins and scripts and just copied them into the new folders and that was it. Didn’t have to reinstall anything.
    Not sure about workspaces and keyboard shortcuts, guess you could locate the preferences file and move that accordingly and see if it works.
    Johnny Cuevas, Editor
  • Eric Kirk
    I upgraded to CS5.5 and can speak at least to plugins. Most worked without issue and I had a couple that required some work arounds, like manually copying to the CS5.5 plugin folder.
    I know for sure, the Delirium plugin requires you to manually move the plugin. That process is here:
    https://digieffects.com/support/installation_guide#55Win
    It wasn’t too much of a burden at all and I have a ton of plugins.
    Not sure on scripts though.
    Eric
    Eric D. Kirk
    http://www.kirkproductions.com
