Is there an easy way to invert the colors of an object with effects?
In my project, I only have two colors to work with — White and Orange. I want to change the background color periodically to maintain visual interest, but to do that I need to invert the color scheme on my shape layers.
Here’s what it is right now
What I’m looking for an easy way to do
I originally thought the “Change to color” effect might work, but that only affects one color. If I add a second “Change to color” effect, it is applied on top of the other effect, not simultaneously. After doing that, I just have a solid color instead of swapped colors.
I know I can precompose the composition, duplicate it, and change the colors in one of the precomps to the inverted color scheme, but that’s messy and if I need to change something later it will cause many problems and take lots of time.
