Activity › Forums › Avid Media Composer › is there an Avid project setting for NTSC DV/DVCPRO 720 x480?
  • is there an Avid project setting for NTSC DV/DVCPRO 720 x480?
    Posted by John Vasey on June 18, 2013 at 2:12 am
    I am trying to create a new Avid project in version 6.5.2 with settings of NTSC DV/DVCPRO 720×480. I don’t get very far after inputting 30i NTSC. I can then select 4:3 but the raster reads 720 x 486 which is NTSC D1 and it’s greyed out…I can’t change it to 480. I’m trying to accommodate the native settings of several pre-existing Quicktime movies I will be importing (720 x 480) and transcoding to DV 24 411 MXF.
    Is there any project setting available to me that will do this? Or should I just accept it as is…and make the scaling correction when I export a Quicktime reference movie for a standard def DVD? This is not for broadcast…it’s classroom use with students, etc.
    Thanks for any advice that can be offered.
    John
    John Vasey replied 13 years, 3 months ago 2 Members · 2 Replies
  • James Beattie
    June 24, 2013 at 7:05 pm
    Avid makes it conform to 720×486, but it adds a top black bar. Avid can import and ingest native 720×480, but it forces it to conform to 720×480 in the project. You can go under the project settings and modify the Raster setting.
    James Beattie
    ACSR Elite/Avid ACI, Apple Certified Technician
    Consulting for Workflow and Digital Technologies at Comprehensive Technical Group
  • John Vasey
    June 28, 2013 at 7:21 pm
    Thanks very much for your tip…John
