Activity › Forums › Apple Final Cut Pro Legacy › Is there a way to tell if HD files are interlaced or progressive?
  • Is there a way to tell if HD files are interlaced or progressive?
    Posted by Steven Lim on November 8, 2010 at 2:04 pm
    Hi there,
    I have received some HD files in Apple Pro Res, XDCAM 422 and some HDCAM tapes too. According to the sender, they are all in 1080 50. However, there is no mentioning in the label nor slate if the content is progressive or interlaced. Is there anyway for me to find out assuming the sender have no idea too? If so, what are the characteristics i should look out for in a file or HDCAM/HDCAM SR tape?
    Steven
    Paulo Jan replied 15 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    November 8, 2010 at 2:54 pm
    If it says 50, then it is most likely interlaced. 1080p50 is a VERY rare format, and XDCAM and HDCAM do not shoot that format.
    Shane
  • Steven Lim
    November 8, 2010 at 3:33 pm
    Thanks for the reply Shane. That surely helped alot but are they ways I could tell if no information was provided at all. For example, by using the get info function in QuickTime for file based materials or perhaps an indication on the HDCAM players on the display? If so, please advise. And if that is not possible, are there any ways I can determine the above mentioned other than looking out for interlacing tell tale signs (combing effect) by jogging the video at scenes where action and movement?
    In addition, are there ways to identify video with progressive segmented frames too?
    Sorry to be so long winded but I need a quick way to
    determine the above and I have no idea how to go about doing it. This information is required for data entry into our DAM and I can’t have our librarians coming to me each and every time the material received is missing that info.
  • Shane Ross
    November 8, 2010 at 7:46 pm
    [Steven Lim] “by using the get info function in QuickTime for file based materials “
    Nope, that only tells you what codec you are using, and the frame size. Not “I” or “P”.
    [Steven Lim] ” perhaps an indication on the HDCAM players on the display?”
    Yeah, that will tell you. If it says PSF, then it is progressive.
    [Steven Lim] “In addition, are there ways to identify video with progressive segmented frames too?”
    When the deck says PSF. Also, anything that is an interlaced format, but progressive, then it is PSF. 1080i 24p…that’s PSF.
    Shane
  • Michael Gissing
    November 8, 2010 at 11:07 pm
    HDCam will be interlaced. psf footage is progressive images in an interlaced frame. If you were told everything is 1080 50 then it will be i.
  • Zak Ray
    November 8, 2010 at 11:18 pm
    If you’re strictly talking about files, you can use a utility like MediaInfo to analyze it.
    https://mediainfo.massanti.com/
  • Steven Lim
    November 9, 2010 at 12:33 pm
    Thank you all so much for the insight provided. You guys are great!
    Cheers!
    Steven
  • Paulo Jan
    November 9, 2010 at 2:00 pm
    You can always import it into After Effects, use “Interpret footage” and then step field to field (or frame to frame), to see if you perceive any artifacts.
