Activity › Forums › Apple Final Cut Pro Legacy › Is there a way to Search Markers???
Posted by Paul Factora on June 7, 2009 at 9:15 pmI’ve marked & labeled about a thousand markers throughout 25 clips and wanted to somehow bring up a list of shots that had a specific actors name in the Marker dialog.
Is this even possible???
FCP 6.05
Paul
Erin Chan replied 16 years, 9 months ago 6 Members · 12 Replies -
Shane Ross
June 7, 2009 at 11:06 pmThe clip in the browser, see how it now has a triangle (called a disclosure triangle) on the left of it? Click on it and you will see a list of your markers. And you can press CMD-F to find what you want.
Shane
Read my blog, Little Frog in High Def -
Paul Factora
June 7, 2009 at 11:38 pmyeah, that was the first thing I tried. It won’t give me a list, even when I type in clips and markers that I know are there it won’t give me a list. :
Paul Factora
June 7, 2009 at 11:46 pmok wait.
this is weird. I click ‘Find Next’ and it will highlight the first item that matches in the bin.
I click ‘Find All’ and it tells me that nothing matches????
Shane Ross
June 8, 2009 at 1:03 amHmmm…it’s working for me. I made 12 markers, 6 of them with the same word. I pressed CMD-F and typed the word. it highlighted it for me. I pressed CMD-G, it found the next one…then the next one, then the next one.
Worked fine.
Shane
Tom Wolsky
June 8, 2009 at 1:44 amAre you doing that in the timeline? I think Paul is talking about the Browser. Digital Heaven has an app that will print out marker info.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Shane Ross
June 8, 2009 at 1:48 amNo, I am doing this in the Browser.
Shane
Paul Factora
June 8, 2009 at 1:49 amYes Browser.
I’ll check out the Dig haven app.
Much Thanks Tom
-p
Jeremy Garchow
June 8, 2009 at 9:47 pm[Paul Factora] “wt!? “
Yes, it’s a tawdry system at best. I hope that FCS gets a metadata overhaul whenever the next version hits the air waves.
I think that closing FCP and deleting any cache files helps with this. Sometimes simply relaunching the FCP project helps as it seems to add the new text into the database somewhere.
Jeremy
