Activity Forums Adobe After Effects Is there a way to remove/reduce LCD scan-inteferance when first recorded in AE?
  • Is there a way to remove/reduce LCD scan-inteferance when first recorded in AE?
    Posted by Erik Høirup on August 17, 2011 at 5:10 pm
    Hi!
    Some of our theater-clients have switched to large LCD-video walls on stage in stead of normal probs.
    I know that if I can find the right shutter-speed, I can eliminate this, but som large LCD-walls are made with multiple LCD-screens, which might no all have the same scan-frequency. So the correct shutter only partialy solves this…
    I am trying to find out if there is an AE filter, which can remove/reduce the artifacts from the LCD´s(don´t know if I should call it scanlines, or …). Typically the closeupcameras look bad, because they get quite close to the LCD´s as well.
    Looking forward to your input 🙂
    Erik Høirup
    Erik Høirup replied 15 years ago 39,529 Members · 1 Reply
  • Erik Høirup
    August 17, 2011 at 5:36 pm
    Hi Dave!
    Thanks for you quick reply.
    You are quite right, that it would help finding out more in advance, and get the cameras lined out correctly from the start.
    But I have already experienced, that the scanfrequency didn´t go with sll the monitos in a lcd-wall, so most footage looked allright, wereas the latter was full of moire etc. In this case, I can only see this to be solved in post …
    Erik
