Activity › Forums › Apple Final Cut Pro › Is there a way to remove all audio automation on an entire project?
  • Is there a way to remove all audio automation on an entire project?
    Posted by Cybil Lake on May 14, 2019 at 3:51 pm
    An editor adjusted the volumes of my audio tracks and my sound editor wants them removed.
    thanks!
    Jeremy Garchow replied 7 years, 4 months ago 3 Members · 6 Replies
  • Helgi Thor
    May 14, 2019 at 6:06 pm
    Select all and hit opt-0 (thats a zero).
    Helgi Thor
    Editor
    Fortaleza
    Brazil
  • Cybil Lake
    May 14, 2019 at 7:37 pm
    wow! Thank you so much!
    So I am assuming that this makes all the volume the same?
    and if I have slow-downed some video and its audio – does this affect that as well?
    question – does this – change the attributes of the video image in any way?
    thanks !
  • Cybil Lake
    May 14, 2019 at 8:04 pm
    HI – unfortunately OPTION zero didn’t work.
    do you have any other suggestions?
  • Helgi Thor
    May 15, 2019 at 3:21 pm
    It doesn’t make all the volume the same, but it resets the volume to its original state and removes all keyframes. And won’t affect the video in any way.
    But it’s always a good idea to duplicate the project (sequence) before doing anything drastic.
    Helgi Thor
    Editor
    Fortaleza
    Brazil
  • Helgi Thor
    May 15, 2019 at 3:23 pm
    Well, maybe the keyboard shortcuts have been changed. You can also use the menu command Reset 0dB in Adjust Volume from the Modify menu.
    Helgi Thor
    Editor
    Fortaleza
    Brazil
  • Jeremy Garchow
    May 15, 2019 at 4:39 pm
    There’s another command to set so volume to a specified level. Modify > Adjust Volume > Absolute and then type a value (like -6 or whatever will work for you).
