Activity › Forums › Adobe Premiere Pro › Is there a way to paste a clip from the clipboard into a gap?
  • Is there a way to paste a clip from the clipboard into a gap?
    Posted by Amy Young on August 8, 2017 at 4:19 pm
    I can’t find the solution, maybe there isn’t one.
    I have copied a clip from sequence A and want to fill a gap in the timeline of sequence B. But it paste-inserts — everything gets moved to the right. I just want to fill a gap. I have selected the “empty” space, but it still pastes the whole thing (which is longer than my gap). I don’t want to set in and out points in the source monitor, etc. I just want to put whatever’s in the clipboard into whatever space there is.
    Thanks for any suggestions!
    Amy Young replied 9 years, 1 month ago 4 Members · 6 Replies
  • Todd Perchert
    August 8, 2017 at 4:36 pm
    I don’t know if there’s a shortcut or not. I usually just paste on a track above and trim.
    TC
  • Amy Young
    August 8, 2017 at 5:01 pm
    Thanks — I do too, but sometimes there’s clips above and below, and there’s no “extra” room…
  • Andy Patterson
    August 8, 2017 at 5:35 pm
    You would have to set an in and out point on the timeline to have the video clip fit to fill. I don’t think there is a short cut method.
  • David Roth weiss
    August 8, 2017 at 6:01 pm
    In that case you either create a new track or paste at the end of your timeline then trim and move.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Amy Young
    August 9, 2017 at 4:55 pm
    Thanks – I also put at the end and trim then move, but I was wondering if there’s some other method that’s more precise and faster. Sounds like there isn’t – oh well!
  • Amy Young
    August 9, 2017 at 4:56 pm
    Thanks — good to know I can stop searching for a shorter method…
