Activity Forums Adobe After Effects Is there a way to NOT make brush strokes pixelate when enlarging them?
  • Is there a way to NOT make brush strokes pixelate when enlarging them?
    Posted by Daniel Haskett on May 21, 2005 at 2:08 pm
    hi there
    Basically is Vector Paint the only way to have brush strokes that wont pixelate when enlarged? I just find it alot more confusing that the normal paint brush option which does unforuntately pixelate.
    cheers
    Dan
    Skacey replied 21 years, 3 months ago 2 Members · 1 Reply
  • Skacey
    May 22, 2005 at 9:53 pm
    Second option is to make a comp large enough so that when you zoom in the pixels are one-to-one (full resolution) then start with that comp reduced in size – when you zoom in you will be approaching 100% size and not have the pixelization.
    One limit I had to get past was always thinking that my comp should be the size of the screen – you can get some fantastic results by starting with a larger comp and scaling down (render times will be increased though)
