Activity Forums Avid Media Composer Is there a way to map the audio with the keyboard?
  • Shane Ross
    August 13, 2012 at 8:38 am
    In what way? You really need to elaborate here.
    Shane
    Little Frog Post
  • Glenn Sakatch
    August 13, 2012 at 1:54 pm
    It would be a pretty elaborate keyboard map that could have a button for each possiblility.
    1-1
    1-2
    1-3
    1-4….
    16-1
    16-2
    16-3
    Glenn
  • Frederic Lumiere
    August 13, 2012 at 5:16 pm
    oooh, cool! Didn’t know you could do that.
    Often, I need to link 3-1 because it’s synced audio. How do you do that in Command Palette?
    Looking at it now but I only see the tracks, not mapping.
  • Frederic Lumiere
    August 13, 2012 at 5:20 pm
    So I would like to map the audio from the source to the audio in the sequence without using my mouse (click and drag)…
    For example, in FCP, you press AUDIO 1 then AUDIO 2 right after and it maps AUDIO 1 from the source to AUDIO 2 in the timeline.
  • Frederic Lumiere
    August 13, 2012 at 5:25 pm
    Ha! looks like I got my answer. If I’m in the source, the audio track buttons work for the source and same for the sequence. By switching from source to sequence it maps the tracks just with the keyboard.
    Cool. Thanks!
  • Glenn Sakatch
    August 14, 2012 at 1:43 pm
    I think you misunderstood my answer. Point is that if you could do that kind of mapping, you would have to be a rocket scientist to memorize each possible combination.
    just turn on auto patch on your timeline settings. Avid usually does a good job for figuring out the basic patches.
    Glenn
