Activity Forums Adobe Premiere Pro Is there a way to make a title snap to the length of a clip?
  • Is there a way to make a title snap to the length of a clip?
    Posted by Sean Bond on March 28, 2017 at 9:54 am
    I have lots of titles they all need to just be the length of a video clip in the timeline. Is there a way to quickly do this? At the moment im dragging them all in where they default to 5 seconds then changing the length to fit the clip, and there must be a quicker way.
    Andrew Mcdonald replied 9 years, 5 months ago 3 Members · 2 Replies
  • Mike Jones
    March 28, 2017 at 1:21 pm
    In the project bin area where your titles are kept. If you highlight /click on, the files whose duration you want to change. Right click and select Speed/Duration. You can chance the duration for all those titles at once.
  • Andrew Mcdonald
    March 28, 2017 at 6:39 pm
    In the timeline, move the playhead to the end of your clip. Select all the video tracks that contain titles you want to extend (for best results, make sure each title you want to extend is on its own, separate track) and use the Extend Previous Edit to Playhead shortcut — the default is Shift + Q. Like the name implies, this should snap the end points of all your title clips to the playhead.
    Hope this helps!
