Activity › Forums › VEGAS Pro › Is there a way to make a reverb effect gradually get louder as the track goes on?
  • Is there a way to make a reverb effect gradually get louder as the track goes on?
    Posted by Bradley Graham on February 7, 2013 at 9:28 pm
    I’m applying the reverb effect to some of my audio tracks, and what I want to do is have the track start off with no reverb, and then have the reverb grow as the track goes on, until it becomes a full on echo. Can this be done? Thanks
    Edward Troxel replied 13 years, 7 months ago 2 Members · 4 Replies
  • Edward Troxel
    February 8, 2013 at 5:15 pm
    If you use the “Reverb” effect, you can keyframe the effect.
    If you use the “ExpressFX Reverb” effect, you cannot.
    To keyframe the effect, click on the FX button on the track, add that effect, and the click on the “Configure FX Automation…” on the far right top. Select the items you wish to keyframe and then you can control them with envelopes on the timeline.
    Edward Troxel
  • Bradley Graham
    February 14, 2013 at 8:41 pm
    sorry but I couldn’t find the ‘configure fx automation’ option, could you give me very specific instructions on how to find that? Thanks
  • Bradley Graham
    February 15, 2013 at 5:31 am
    Actually I found ‘Configure FX Automation’ but I couldn’t figure out how to select the Reverb effect, it just shows three tabs “Track Noise Gate”, “Track EQ”, and “Track Compressor”
  • Edward Troxel
    February 15, 2013 at 4:52 pm
    You have to add the reverb effect. Those three are the default ones on the track. You have to add reverb.
    Edward Troxel
