Activity › Forums › Video Copilot › Is there a way to Keyframe a Texture in Element 3D
Posted by Gabe Blank on September 25, 2018 at 11:50 pmKalleheikki Kannisto replied 8 years ago 2 Members · 1 Reply -
1 Reply
September 26, 2018 at 10:53 amA few ways, depending on what you need to accomplish.
1) Directly in the Effect Controls you can only keyframe the UV offset.
2) As I recall, if you set two different materials for the two groups in Animation engine, it will interpolate between them.
3) The most flexible approach is to use AE layers as texture maps in Element. This way anything you do in the layers will update in Element.
Senior Graphic Designer
