Activity › Forums › Adobe After Effects Expressions › Is there a way to keep a block of text always vertically centred?
  • Is there a way to keep a block of text always vertically centred?
    Posted by Darryl Torke on June 18, 2014 at 6:04 pm
    I am making a template for a basic AE user in which the user inputs some text. The paragraph setting of the block of text is set to ‘center’, so that handles itself. However, I was wondering if there was the equivalent of a vertical ‘center’ that would always keep the text block in the middle of the screen regardless of how many lines the text was.
    As I have it set the user has to manually move the text block up and down which gives room for error. I’d like it to be set-it-and-forget-it ideally.
    John Mitchell replied 9 years, 10 months ago 4 Members · 4 Replies
  • Kevin Camp
    June 18, 2014 at 9:28 pm
    that would be nice (you might suggest it with a feature request):
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    you can do it if you force the user to type hard returns (so you wouldn’t want to use a block). if you do that, you can use an expression like this to count the hard returns and the change the position accordingly:
    offset = 24;
    txt = text.sourceText.split(‘\r’);
    y = (txt.length-1)*offset;
    value-[0,y]
    you just need to figure out the offset value for the font/size that you are using.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Darby Edelen
    June 18, 2014 at 10:43 pm
    Here’s an animation preset that will center text vertically.
    7634_centertextvertically.ffx.zip
    The preset applies two sliders to the text layer. The first one needs to match the line height of the text and the second defines the maximum number of lines the expression selector will work with (if more lines than that value are entered then it will no longer vertically center, use a high value).
    It also applies a text animator and expression selector that work together to offset the anchor point of all lines of text by the same amount based on how many lines of text there are.
    This works with paragraph text or point text. There’s no way to dynamically resize a paragraph text layer’s bounding box so you’ll likely need a very tall bounding box if using paragraph text. You may need to adjust the layer’s anchor point some to get the positioning you desire.
    Darby Edelen
  • Darryl Torke
    June 19, 2014 at 2:04 am
    Thanks so much guys. Crazy AE doesn’t have this feature innately, but what can you do.
  • John Mitchell
    December 2, 2016 at 4:17 am
    Kevin – that’s brilliant!
    Your script is better than one that automatically centres the text on layer because that will automatically centre it around any vertical point. The offset needs to be half the value of the line spacing value – I don’t know if you can reference that with an expression. I tried to search the web and it seems you can’t – but I’m an expression novice.
    So I did it with blunt force – first I set my line spacing to 0, then I added the line spacing animator control to the text layer.
    I then adjusted the expression to:
    temp = thisComp.layer(“Text1”).text.animator(“Animator 1”).property.lineSpacing[1]
    offset = [temp]/2;
    value-[0,y]
    Where it says “Text1” – that is the layer name of the text layer.
    If you don’t want to rename your text layers then you can always use a Control slider on a separate layer. I created one called LineSpacing and pickwhipped the line spacing animator control to it.
    You then have to adjust that expression unless you want to indent as well as line space to:
    temp = thisComp.layer(“LineSpacing”).effect(“Slider Control”)(“Slider”);
    [0, temp]
    Then the expression for the text value position property is:
    offset = [temp]/2;
    value-[0,y]
    The only thing you lose with this is the AUTO setting in line attributes but I have found in the past that most fonts simply use the font size value for that.
    temp = thisComp.layer("LineSpacing").effect("Slider Control")("Slider")
    offset = [temp]/2;
    txt = text.sourceText.split('\r');
    value-[0,y]
