Activity Forums Adobe Premiere Pro Is there a way to have effect keyframes copy together with a clip?
  • Is there a way to have effect keyframes copy together with a clip?
    Posted by Thomas Piper on February 21, 2019 at 4:16 am
    What I’m trying to do is copy sections from a previous edit into a new sequence. When I do this, none of the effects keyframes on any of the clips copy over together with the clips. I have to individually copy and paste attributes for each clip from the old sequence to the new.
    Is there some preference that I don’t have set correctly? Or any way to have keyframes copy over when copying and pasting?
    many thanks
    Tom
    Thomas Piper replied 7 years, 7 months ago 1 Member · 1 Reply
  • Thomas Piper
    February 23, 2019 at 12:51 am
    Thanks Dave. Is there a technique you use if you’re copying and pasting multiple clips at the same time? What I’d like to be able to do is take an entire section of one sequence and copy it into another sequence. But when I do so, none of the keyframed effects copy over with the clips. I’m stuck having to add them back individually (I copy and paste attributes for each clip, but your method would work for it too).
    thanks again
    Tom
