Activity Forums Adobe After Effects Is there a way to have an adjustment layer only affect a couple layers?
  • Is there a way to have an adjustment layer only affect a couple layers?
    Posted by Aza Allen on March 20, 2010 at 6:31 am
    I know an adjustment layer affects everything below it, and I can’t move my layers down or they’ll be hidden by another layer, so how can I accomplish this?
    I want to apply an effect to only a few layers, but wanna make it easy to animate the effect. I can’t pre-compose the layers I want to affect either, or I lose my 3d interactions.
    Thanks all for any help!
    Make sure to check out my Heroes Fan Film at https://ruesterprod.blip.tv
    Roland R. kahlenberg replied 16 years, 5 months ago 3 Members · 2 Replies
  • Baran Venkatasamy
    March 20, 2010 at 8:36 am
    hi aza
    https://aescripts.com/create-trimmed-adjustment-layer/
    hope this script will help you
    baran
  • Roland R. kahlenberg
    March 20, 2010 at 8:44 am
    Perhaps you alrady know this, but just to ensure; with 3D layers, their ordering within the layer panel, is inconsequential. If you have a combo of 2D and 3Dlayers and you still have issues reordering them then you should use Expressions to link the effect to a single ‘Null’ layer.
    For this method, apply the effect to a Null. Apply the same effect to the first of the layers that require the effect. Use Expressions to link the properties for the effect to the same effect properties on the Null. Select this layer’s name from within the Effect Controls Panel and save as an Animation Preset. Select the other layers that require the effect and then apply te Animatin Preset you just saved.
    You can now control the properties across all the layers by affecting the Null layer’s effect properties.
    HTH
    RoRK
    Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
