Activity › Forums › Apple Final Cut Pro Legacy › Is there a way to get more than 1 viewer?
Posted by Emy Fehmi on September 29, 2006 at 12:45 amFor complex moves of more than one layer, it would be helpful to have more than one viewer window and maybe even 3 or 4. Otherwise it seems hard to make things move together…
Any suggestions?
I think I read it is possible to get multiple viewers, but i have never been able to make it happen…i am finally frustrated enough to ask the question : (
thanks,
emyEmy Fehmi replied 19 years, 11 months ago 7 Members · 10 Replies -
David Roth weiss
September 29, 2006 at 12:47 amWINDOW — ARRANGE — MULTIPLE EDITS or DUAL SCREEN MULTIPLE EDITS
Emy Fehmi
September 29, 2006 at 1:04 amI’ve only got dual screen editing…not multiple edits as an option. i am running Final Cut 5.0
Am I behind in the times or something?
thanks,
emy -
David Roth weiss
September 29, 2006 at 1:09 amHuh??? Thats funny. I don’t know what’s up with that.
DRW
Emy Fehmi
September 29, 2006 at 1:11 amI’m confused…
Do you think that I should have that option available with 5.0?
or do i have to do something to make the option appear?
thanks,
emy -
Tom Wolsky
September 29, 2006 at 1:19 amWhat computer are you using? Make sure the monitor resolution is at least 1280xsomething (can’t remember the number). Make sure the dock isn’t cutting into that. If there isn’t enough screen space on your monitor multiple edits won’t be available in the Window menu.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Liam Stephens
September 29, 2006 at 1:21 amHmm not in front of my FCP but…Try opening the clip in the viewer by going file>open>whatever.mov then the clip should open in a viewer window by itself and u can open another clip in another viewer by selecting it in the browser. Thus a sneaky workaround for multiple viewers. To have even more viewers, open more clips via the file menu. Kinda messy but should work for u as u can edit in the new viewer.
good luck
L -
Uli Plank
September 29, 2006 at 5:54 amJust tear the first viewer off by it’s tab and drag it somewhere else. The next clip will generate a new tab, and you can tear it off again. You can have viewers all over the place 😉
Regards,
Uli
Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
Kevin Monahan
September 29, 2006 at 3:55 pmControl click on the new clip and choose, Open in New Viewer.
Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com
Pres. SF Cutters -
Andy Mees
September 29, 2006 at 4:33 pmhold down option (alt) and then just double clip on the clip icons in the browser window
Emy Fehmi
October 2, 2006 at 8:04 pmThanks so much for all of your suggestions!
I’m not sure if anyone will read this now that it is so old and far down the list but here goes…
The suggestions are all great, I have gotten many viewer windows to appear, however in trying to track changes in multiple layers within the timeline at the same time, that have already been altered, I am still having difficulty.
All of these viewers only seem to appear on clips in the browser window and control-click gives no option in the timeline to open the window in a new viewer. Is this a limitation of the program? Or is there some way to make that happen too?
thanks
emy
