Activity Forums Adobe After Effects is there a way to flip a set of keyframes?
  • is there a way to flip a set of keyframes?
    Posted by David Lieberman on February 21, 2008 at 8:03 pm
    i have a set of keyframes from a path for a write-on effect to follow…i want it to follow it the exact opposite way around…is there a way to do this? meaning, flip the keyframes entirely?
    thanx for the help.
    Darby Edelen replied 18 years, 6 months ago 2 Members · 2 Replies
  • David Lieberman
    February 21, 2008 at 8:09 pm
    thank you
    thanx for the help.
  • Darby Edelen
    February 21, 2008 at 8:26 pm
    [Dave LaRonde] “There’s some command called Time Reverse Keyframes”
    Sure is! You can select the keyframes in question, right click one and select Keyframe Assitant > Time Reverse Keyframes.
    If you want a copy of the keyframes make sure you copy and paste them somewhere else on the timeline before your time reverse them.
    I often use this for duplicating fades or camera moves and reversing them.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
