Activity Forums Adobe After Effects Is there a way to fade in between multiple cameras on one composition?
  • Is there a way to fade in between multiple cameras on one composition?
    Posted by Daniel Haskett on June 24, 2007 at 3:31 pm
    Hi there
    Basically, Ive got a couple of cameras on the same composition doing slightly different movements and it’d be cool to fade in between the two. Is this possible…..or what would be the best way to do something like this? do i need to render out each camera as an avi then bring into premiere and fade or is there a way in AE of doing it? or can i bring the composition into premiere?
    cheers!
    dan
    Brian Charles replied 18 years, 11 months ago 2 Members · 1 Reply
  • Brian Charles
    June 24, 2007 at 7:51 pm
    Camera layers do not have opacity settings. You could create separate compositions, one for each camera, then place these in another comp and faded between them there. No need to render other than to speed rendering the final comp
