Activity Forums Apple Final Cut Pro Is there a way to export a single audio clip from the FCPX project (only one clip, not all of them as one)?
  • Is there a way to export a single audio clip from the FCPX project (only one clip, not all of them as one)?
    Posted by Gus Tozzer on December 4, 2012 at 9:20 pm
    Guys, I know it’s possible to export all the audio material from the project using the export media command, but is it possible to export specifically just one single audio clip from the project?
    Jari Innanen replied 13 years, 9 months ago 3 Members · 4 Replies
  • Tom Wolsky
    December 5, 2012 at 1:47 am
    Select the clip. Make it a compound clip. You can either open the compound clip and export from there, or export the compound from the browser. This only applies to 10.0.6.
    All the best,
    Tom
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
    “Complete Training for FCPX” from Class on Demand
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Tom Wolsky
    December 5, 2012 at 1:49 am
    Select the clip and make it a compound clip. Either open the compound into the timeline, or export it from the browser. This applies to 10.0.6.
    All the best,
    Tom
  • Gus Tozzer
    December 5, 2012 at 1:01 pm
    I’m still using the 10.0.5 version but thanks anyway for the tip Tom! Don’t you know any other technique to do this? By the way, do you know why FCPX has this gap, I mean, why didn’t they put a command on menu to do this kind of a task since it can be so useful and important?
  • Jari Innanen
    December 5, 2012 at 1:58 pm
    I’m not sure if you could use share in 10.0.5 when you opened a clip in its own timeline aka using “Open in Timeline”-command?
