Activity › Forums › VEGAS Pro › Is there a way to edit an audio event to make it sound like it’s coming through a “filter,” so to speak?
Posted by Raymond Pace on November 10, 2011 at 4:11 amI’m not completely sure how to describe what I’m trying to achieve– it’s sort of like taking a clear, crisp audio event and sort of… making it sound like it’s coming out of a radio with poor reception or something. Not with static or anything, but just altering the way the voice sounds.
Is there any way to do this in Vegas?
Mike Kujbida replied 14 years, 10 months ago 4 Members · 6 Replies -
Ted Snow
November 10, 2011 at 4:19 amIf you want it to sound like it’s coming from a transistor radio, add the track EQ and cut the lows. Just experiment with sweeping the low cut back and forth while playing the clip.
ASUS P8P67 Deluxe MB
EVGA GeForce GTX 560 Ti 1 GB DDR 5
Intel i7 2600k 3.4 Ghz
Corsair HX750 power supply
Two Seagate Barracuda 500g SATA III drives
16 Gig G.Skill Ripjaws DDR3 1600
Canopus ACEDVio card
Thermaltake V9 BlacX Edition case
Xigmatek Dark Knight CPU Cooler
Win 7 Pro
VEGAS 8.0
VEGAS 11.0 32 & 64 bit
Sony VX2100
Sony HVR-Z7U
Sony HDR-CX130
Alesis HD24 -
Raymond Pace
November 10, 2011 at 4:22 amHow exactly do I do that? I don’t have much experience with audio editing in Vegas.
Thanks for the quick response.
Ted Snow
November 10, 2011 at 5:08 amYou just open the track FX by clicking on the FX button in the section where the volume slider is. Hover your mouse cursor over the different buttons and you will see which one is the FX. Add the track EQ from the list.
Win 7 Pro
VEGAS 8.0
Sony VX2100
Sony HVR-Z7U
Sony HDR-CX130
Alesis HD24 -
Ted Snow
November 10, 2011 at 5:22 amActually, when you open up the FX window, the Track noise gate, EQ, and compressor is already assigned to the track. Click on the EQ window and pull down the low frequencies…the number 1 dot. Once you pull it down, sweep it back and forth while your audio track is playing and you can hear the changes.
Win 7 Pro
VEGAS 8.0
Sony VX2100
Sony HVR-Z7U
Sony HDR-CX130
Alesis HD24 -
Jason Monroe
November 10, 2011 at 5:43 amyes you can select your fx panel and then pull up all the filters you should probably select the resonant filter, there is a tutorial of this on vegaspreoeditors.com
Mike Kujbida
November 10, 2011 at 8:20 amAdd the Parametric EQ and choose the Phone line effect preset.
