Activity Forums Adobe After Effects Is there a way to do white balancing in post?
  • Is there a way to do white balancing in post?
    Posted by Eddie Sheng on April 13, 2008 at 5:15 pm
    Hi all… Is there a way to point to a spot on the video and tell it to stay the same colour throughout and graph whatever changes onto the entire video?
    Best I can describe it is manual white balancing, where you point to a white spot and say “this will always be white”…
    Thanks.
    Harrison Willett replied 18 years, 5 months ago 2 Members · 1 Reply
  • Harrison Willett
    April 14, 2008 at 12:55 am
    If I am understanding you correctly you want to alter the color of only a specific color or range of colors to do this you can use Effect > Color Correction > Change to Color. Normally I just use Effect > Color Correction > Curves for color correction though. Hope this helps.
