Activity › Forums › Adobe After Effects › Is there a way to create simple background for text layer?
  • Is there a way to create simple background for text layer?
    Posted by Hawk Phil on August 23, 2012 at 7:36 am
    I just want to create a rectangle area around the text as the background of the text layer. That’s it. Very simple. I don’t want to create a text layer and then another rectangle layer. The reason is I want the spacing between the rectangle border and the text the same. How do I do this? Or is it better to do in Photoshop and then bring over?
    John Cuevas replied 14 years ago 3 Members · 4 Replies
  • Hawk Phil
    August 24, 2012 at 4:54 am
    Any help?
  • Vishesh Arora
    August 24, 2012 at 7:17 am
    Mr. Phil
    To make your text at the center of your bg(or Rectangle) :
    1. Press ( ‘ ) apostrophe.(Enable your grid)
    2. Disable Live Update Button.(Bring your wireframe while moving text)
    3. Now you can put your text layer at the center with same space between rectangle and Text.
    Check the while moving the text and when wireframe is visible, the two diagonals bisect each other. Use that ponit as center.
    Vishesh Arora
    VFX and Motion Graphics Artist
    https://digieffects.wordpress.com
  • Hawk Phil
    August 24, 2012 at 7:41 am
    Hi Vishesh,
    Thanks for the response but actually I am looking for an automated way to have text background color, regardless of text length. For example, if I make PRESS THIS as the text, I like the background (blue) with same spacer to the border of the blue rectangle:
    https://typekit.files.wordpress.com/2011/02/31.png?w=560&h=204
    Then if I make copy and change the text to CANCEL or HELLO, etc… the background blue should still be relative to inner text.
    Is there a way to do this?
  • John Cuevas
    August 24, 2012 at 12:10 pm
    Actually did a little looking around and this isn’t that easy to automate. I had thought an expression might be able to be linked from the height and width of a text layer to a shape layer, but apparently text doesn’t have a physical height and width to use. I haven’t seen an automated way of doing what you are asking yet.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
