Activity › Forums › Apple Final Cut Pro › Is there a way to copy-drag a clip or transition?
  • Is there a way to copy-drag a clip or transition?
    Posted by Frank Manno on February 21, 2013 at 3:31 am
    Is there some way to duplicate a clip or a transition by dragging it with the mouse?
    Like a CTRL-DRAG or something like that which will copy while dragging?
    If I have a transition right in front of me and I want to place another a second away, would be easier if I could just somehow drag a copy of it to the new position. Same thing with a clip..
    -Frank
    Bret Williams replied 13 years, 7 months ago 2 Members · 2 Replies
  • Frank Manno
    February 21, 2013 at 3:33 am
    I just worked it out — OPTION-DRAG
  • Bret Williams
    February 21, 2013 at 3:56 am
    Yup. But annoying that when you want to do it for a clip, like in FCP 7, and hold down the shift key to keep it inline vertically, that the shift key actually negates the copy. Yet another hot key combo from FCP 7 that is destructive in X. Another destructive favorite is W. Trying to turn on and off the wireframe in X never works. Then later you discover new clips all over your timeline. Well, the same clip usually. Muscle memory can be hell.
