Activity › Forums › Apple Final Cut Pro Legacy › Is there a way to convert quicktime files to pro res format??
Posted by Katrina Choy on September 20, 2010 at 7:32 pmHi there, I have just been asked to send a film in apple pro res format, but i edited my film in premiere pro cs4. Is there a way to convert the latter to pro res format??? Or am I talking nonsense…
Rafael Amador replied 15 years, 11 months ago 7 Members · 8 Replies -
Shane Ross
September 20, 2010 at 7:41 pmYou need FCP 6 or 7 to encode to ProRes. They are the only software that allow for ProRes encoding.
Explain your dilemma and ask for an alternative option.
Shane
Read my blog, Little Frog in High Def -
Matthew Bradshaw
September 20, 2010 at 9:23 pmNo you are not talking nonsense! You need to export your finished movie and then convert it to prores. As Shane says, you will need access to FCP 6 or 7 in order to convert to prores.
Matt. -
Katrina Choy
September 20, 2010 at 9:41 pmTHanks Shane and Matt! I dont have fcp so will use yousendit instead! thanks for your advice!
Michael Sacci
September 20, 2010 at 11:10 pm[Katrina Choy] “I dont have fcp so will use yousendit instead!”
How does yousendit get you video into the ProRes codec?
Tucker Quenette
September 20, 2010 at 11:12 pmwould another option be to play it to a device such as a ki pro from aja?
Michael Sacci
September 21, 2010 at 12:00 amWhile that would work, that is a pretty expensive way to do it. My thinking is that a person with FCP most likely would own a Ki Pro.
Doug Nichol
September 21, 2010 at 3:50 amYou can also just download MPEG Streamclip and convert the QT to ProRes.
Rafael Amador
September 21, 2010 at 5:04 am[Doug Nichol] “You can also just download MPEG Streamclip and convert the QT to ProRes.
Doug, the only way to get Prores exporting is having FC 6 up installed in the computer.
rafael
