Activity › Forums › Adobe After Effects › Is there a way to change DPI units in AE?!
  • Is there a way to change DPI units in AE?!
    Posted by Matthew Woods on December 1, 2011 at 3:35 pm
    Now before all of you assume I’m a photoshop guy and spout DPI has no meaning in video (believe me I have done that enough myself), let me say that I work with museum multimedia and we very often know exactly how big a video is going to be displayed, and I often have to consider the pixels per inch ratio of a video projection to know how big an image will be when projected. I have always assumed AE knew nothing about DPI and did the calculation by hand.
    Anyway, I was just asked for the real world dimensions of some masks in a template that I created. I double clicked on the “shape…” property of the mask path to get the bounding box, and I noticed a dropdown menu for “Units.” Under this menu, I discovered the option to view the bounding box in “inches.” I tried it out, and it seems to assume 72 DPI. Is there any way to change this units DPI value? The fact that an “inches” view option exists leads me to think so, but I can’t find it anywhere. Being able to get real world bounding box dimensions would have the potential of saving me a lot of calculator time.
    -Matt
    Need a quick break from motion graphics?
    Try my game Constellation at:
    https://www.paperdragongames.com
    Matthew Woods replied 14 years, 10 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    December 1, 2011 at 3:48 pm
    I believe that this setting is accessed from your display card’s settings.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Matthew Woods
    December 1, 2011 at 4:20 pm
    Hmm. I don’t seem to have any options for that in my display prefs.
    I’m on a mac, so I don’t get as many display card options.
    Thanks for the thought though.
    -Matt
  • Matthew Woods
    December 1, 2011 at 4:56 pm
    Its not a hard calculation to do. I was just wanting to see if there was a new trick to improve workflow. One trick I have used in the past is to figure out the approximate size of things is to change my grid size based on it. I can then easily turn on the grid to get an idea of how big things are if for example I wanted a person to be life size in a projection. (I wish I could do that on a per project basis rather than in the prefs). In this case I needed an exact size for a number of areas in the template, so I needed to do the calculation a lot. I never knew that AE did anything in inches, so I was surprised to discover this. I’d hoped there was a way to adjust this.
