Activity Forums Adobe After Effects Is There a way to Change all precomp layers comp length from the master comp?
  • Is There a way to Change all precomp layers comp length from the master comp?
    Posted by Malikai666 on June 6, 2005 at 6:01 pm
    Is There a way to Change all precomp layers comp length from the master comp? Does anyone know of a short cut. The problem is if you extend the length of the final comp your precomps still need to be extended. So is there an easier way than going through each precomp and changing the comp lenght there?
    Wes Plate replied 21 years, 3 months ago 3 Members · 2 Replies
