Is there a way to automate transitions on cuts when multiclipping?
Question is outside the breadth of a single project. I consistently am multiclipping 4+ angles together in long sequences of over 75min+
My current work flow leads me to manually paste the fade I want between each cut on each individual cut after I have worked through the sequence once over. My Final cut knowledge base is mainly self taught, so I am wondering if there is a more efficient way to accomplish this, as my current method can be a bit tedious at times. There is no variance in transitions throughout the sequence.
Thanks in Advance.
